3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | yes, the carb.
The gas gets hot, and percolates, then boils the bowl over, and gas overflows and runs out of the lower linkage all over the hot manifold.
I got rid of the Rochester B, and replaced it with a rebuilt Carter YF, and added the spacer/insulator, too.
It doesn't do it all the time, but enough times to bug me.
What possible remedies have been tried?
Suggestions please? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | Is the heat riser that counter weight thingey on the manifold? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | Thanks, that might be the problem. I will look in the manual to see if it contains specs to check it out.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It could be excessive fuel pump pressure. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Is your bowl vent working? | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Is your bowl vent working? obviously to good. | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | bowl vent? I'm not sure the Carter YF has one. But the leaking comes out below the bowl where some linkage goes up in there, suggesting that the bowl overflows inside the carb I guess. | | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | Every carburetor I have even seen or rebuilt (which has been hundreds) have got an atmospheric vent for the float bowl, if it did not, the gas could not be drawn out through any of the jets by vacuum. However, external flooding on these carbs is common. Over choking, excessive fuel pressure, defective float/float valve & seat and in some cases to small diameter of fuel line from the pump to the carb can cause this issue. Question first is? Is it really boiling (from temperature) or being forced out by a pressure issue? Fuel pump pressure and volume test at the carb inlet would be a good test to start with.
Best Regards Will
| | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | how would I go about checking fuel pressure at the inlet? do I need gauges?
but it runs fine most of the time,, it just gets upset sometimes, and it is acting like a heating issue.
I will follow through this weekend with checking the operation of the heat riser spring valve, too
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | scotricker
You say the carb was rebuilt. I read in another forum that some aftermarket carter rebuilt kits contain replacement parts designed for ford.
heres a copy and paste of the passage The issue with the aftermarket rebuilding kits is quite simple. The carburetors made for Chevrolet were made in the 1950’s and early 1960’s. Most of the YF production was for Foorrdd engines, especially the 300 CID 6 cylinder which require more fuel. MOST (not all) of the current aftermarket repair kits contain a fuel valve designed for the Foorrdd engine which has an orifice of 0.101 inches. The fuel valve as used in ALL of the YF carbs for Chevrolet had an orifice size of 0.081 inches. If you do the math, the valve for the Foorrdd has an orifice size which is seventy percent larger! Using this valve in the Chevrolet carburetor will cause at best an over rich condition at idle, and at worst flooding and fuel leakage.
Just something else to look at
Good Luck | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Possibly a small piece of dirt getting into the needle and seat? Have you cleaned the inside of the gas tank or checked it? | | |
