1 members (RLB),
113
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | I got a 4 speed off a junk stovebolt engine that a bolter was throwing out. I have no idea where or what was the original truck. It works fine I have it on the back of my 216 1/2 ton but I would like to find the origins and get gaskets etc. With all the experience on this web site, can someone tell me where would be the id numbers for this tranny would be and what web site if not this one could tell me what chevy vehicle this came out of so I can start the restore project.
This is a 4 speed, with a flipper lever for reverse, the stick can be removed by 1/4 turn of the cap where the stick loads in the top of the tranny, granny first gear and 3 speeds after etc.
Thanks for the help,
Rick,,,,,,,,,
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy elmer46, I don't know what the designation for that tranny is, and I don't think I've ever seen it identified by a number. It is a "crashbox" 4spd, produced between 1937 and 1948, it is the transmission design before the SM420, hope that helps. | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | We called them sliding gear transmissions and I have seen them designated as SG4. The SM in the later transmissions stands for synchro mesh. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Sounds just like what I have in my '41 3/4 ton | | | | | Joined: Dec 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 64 | ive got one of those too..dont know what i will do with it tho...possibly sell it
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | My old tranny is now serving as rebar.
~Jim
