| | | Forums66 Topics128,014 Posts1,055,325 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Well I bet you thought this was a automotive question.
When you dim your house lights do you use less electricity? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no, the lower wattage used by the light is used by the dimmer [as waste heat] - need to use lower wattage bulbs to save power, which automotively speaking happens by having 2 elements in the headlights, one high wattage, one low wattage  Bill | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Thank you Bill, I might have guessed you would have the answer.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It depends upon whether you are using rheostat dimmers or thyristor dimmers. Most dimmers are rheostat dimmers. Thyristor dimmer do not "dump" the unused electricity. Supposedly Lutron sells some energy savings dimmers. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think you will find most dimmers today have electronic choppers in them and thus use less electricity. I believe the electronics is now cheaper to make. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | |
