6 members (Jon G, Oswald, baldeagle, fonz8261, Hotrod Lincoln, 1 invisible), 76 guests, and 3 robots.
Topics128,015
Posts1,055,334
Members48,419
#692341 11/05/2010 8:32 PM
Well I bet you thought this was a automotive question.
When you dim your house lights do you use less electricity?
gazim #692345 11/05/2010 8:37 PM
no, the lower wattage used by the light is used by the dimmer [as waste heat] - need to use lower wattage bulbs to save power, which automotively speaking happens by having 2 elements in the headlights, one high wattage, one low wattage wink
squeeze #692530 11/06/2010 2:11 PM
Thank you Bill, I might have guessed you would have the answer.
gazim #692592 11/06/2010 6:42 PM
It depends upon whether you are using rheostat dimmers or thyristor dimmers. Most dimmers are rheostat dimmers.
Thyristor dimmer do not "dump" the unused electricity. Supposedly Lutron sells some energy savings dimmers.
tclederman #692668 11/07/2010 1:21 AM
I think you will find most dimmers today have electronic choppers in them and thus use less electricity. I believe the electronics is now cheaper to make.
1951 1 Ton Completed
truckernix #693067 11/08/2010 2:28 PM
Thank you.
