8 members (Stewart2, 3B, Peggy M, Steelonsteel, moparguy, Millenimech, 2 invisible),
100
8
Mod | | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 110 | I am finishing the electrical on my 51 chevy truck. I should add this is my first electrical work ever so everything sounds greek to me and english is already my second language...LOL Truck now has a 250 motor and I am upgrading all to 12 volts but keeping the original ignition switch but got rid off the foot start button. It is still using a ballast resistor for the coil.
I am trying to wire a push button under the dash but I am having a bit of an issue. Every decent looking button only has one prong on the back gounds to the body but I believe I need a 2 prong to active the solenoid in the starter...am I wrong? I read somewhere I could use the one prong switch but I need a relay....hence, the problem...how do I wire this??? I already run two wires from the starter, one from the large battery post and the other one from the soleinod post....
I was thinking to run those 2 wires to a horn relay "H" and "B" terminals on the relay and run a wire from the "A" to the one prong switch....can this work or should I just keep looking for a decent looking 2 prong switch....Any one can tell me where I can get one? I just want something small, flush and hopefully small diameter and body length so it won't interrupt anything inside the bottom of the dash.
Please help!!! Thx | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Run the hot lead from your ignition switch to the relay . Works for me.
