0 members (),
49
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Need help on where to connect the throttle cable on a 216 53 5 window. Not sure what type of carb I have,
1953 5 Window 1994 Harley, Heritage Softail Classic 2006 Chevy Colarado I didn't say it was your fault, I said I was blaming you.
| | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Here is how my throttle connection is done on my W1 Carter. my carb setup | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The connection for a Rochester B is the same as a W1 Carter. The throttle cable keeps the rod from falling off the carburetor arm. The cable uses the same bracket as the choke cable. Look at the picture in the post above. If you have the original carburetor on your truck it would be the Rochester B. | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Outstanding info guys, thanks
Charlie
