Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Wally / Montana, farmallb, Peggy M, jasrking, 2-Ton, 1 invisible), 36 guests, and 0 robots.
Topics128,010
Posts1,055,299
Members48,419
#692 02/22/2003 10:35 AM
Apprentice
Apprentice
Hello I have a sm420 trany and I am going to use 16” stock rims can someone tell me what my RPMs would be at 65 if I was to use a 3.08 blazer rear end, and also for the 3.40 I am not that good at this stuff just trying to find the best way to go. :confused:
Truc
#693 02/22/2003 3:14 PM
Junior Member
Junior Member
Curt:
Go to www.ring-pinion.com and use the "RPM" calculator. You will enter, 3.08, 65, and the height of your tire. If you don't know the height, there is another calculator to determine this. If your tire is say a 6.00 x 16, measure the diameter of the tire and divide this figure by 3.14 to get the height. Good Luck.
Denny
