3 members (NJC, Wayne67vert, 1 invisible),
166
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 27 New Guy | | New Guy Joined: Sep 2010 Posts: 27 | I am converting to power steering on my 57. What supports the lower column with this conversion? I am using the original column. | | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | It should come with a bushing for the inside shaft/tube. You can use a L bracket, clamp and a couple of bolts to secure it to the floorboard. Some aftermarket suppliers sell a kit but you can make it up as well. Fred
| | | | | Joined: Mar 2010 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 57 |
Nick 1957 3100 Army Base Runner Cenosillicaphobia
| | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Used a kit from ABS in Orange, California http://www.abspowerbrake.com/If I had it to do over I would cut out the recessed section of the frame web out, section in a plate flush with the rest of the frame and then drill/fit their box/bracket. That way the steering column remains closer to the center of the hole in the floor. You cut the stock column to fit using their kit and fab up a support at the floor for the column. | | |
