Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (NJC, 1955 1 Series, Wayne67vert, 1 invisible), 141 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
#686770 10/17/2010 12:31 AM
Y
Y Offline
I am converting to power steering on my 57. What supports the lower column with this conversion? I am using the original column.
It should come with a bushing for the inside shaft/tube.
You can use a L bracket, clamp and a couple of bolts to secure it to the floorboard. Some aftermarket suppliers sell a kit but you can make it up as well.
Fred
What kit are you using?
Nick
1957 3100 Army Base Runner
Cenosillicaphobia
Used a kit from ABS in Orange, California
http://www.abspowerbrake.com/
If I had it to do over I would cut out the recessed section of the frame web out, section in a plate flush with the rest of the frame and then drill/fit their box/bracket. That way the steering column remains closer to the center of the hole in the floor. You cut the stock column to fit using their kit and fab up a support at the floor for the column.
