2 members (Scott '48 2ton, dgrinnan), 141 guests, and 2 robots.
Topics128,163
Posts1,056,962
Members48,458
I was enjoying a favorite passtime... Wandering the Pick-N-Pull. At the exit, there was a 3 spd trans on a table, marked as from a 32 coupe. It had a second lever over the output shaft that I couldn't identify... Looked like an overdrive lever, but I'm not sure.
Casting numbers are these:
Case: 590532
Shifter Housing (floor shift): 590591 7
Other lever housing: 367950 or 867950?
Is this a 3 spd floor shift with overdrive? It is definitely for a torque tube rear. If it is an OD 3spd, would it bolt to my 49 216?
I know, I shoulda taken a picture with my phone.... I never remember to do that.
The original 32 Chevy passenger cars had a "FREE-WHEEL" device, when ingaged it would coast when you let off the gas, this was used in most American Passenger cars in 1932-1933,I heard of stories of a 1933 Chevy hitting 85 mph down hill ,the man that told me about this[said he was young and foolish at the time] was going on that long hill into Utica,NY ,now route 12, when he met two trucks one doing down hill the other going up! some how he got by them at the bottom of the hill he disengaged the free-wheeling never to use it again, I believe it became against the law to use them.
It could be used in your 49.
Chrysler with Borg-Warner, design the over-drive for the 1934 Air-Flow, and later it was used it Chrysler's that had the floor shift. GM was slow to use the O-D's there where some after market over-drives available for Chevies, in the 40's I almost think one showed up on this sight for sale.
Y
yar Offline
Y Offline
Highflyer, that 590532 transmission case was used in various applications in 1932-36 Chevy cars and pickup trucks. In fact, I'm looking for a 590532 empty case right now for my '36 pickup.
What price was on that transmission?
Ray email [email protected]
Ray
Hi Yar.
It's at the Pick-N-Pull yard. All manual RWD transmissions are $99.99 + $25 core... $124.99 + tax Canadian. Their number is (403) 279-7777. I don't know if they ship.
Y
yar Offline
Y Offline
Thanks for the info Highflyer. It's quite a surprise that a dismantler would have such an old piece.
Ray
