3 members (Phak1, Otto Skorzeny, moparguy), 122 guests, and 2 robots.
Topics128,129
Posts1,056,360
Members48,441
#692113 11/05/2010 12:37 AM
I'm doing a steering rebuild on a 1948 3600 and would like to upgrade to a 1953 or 1954 Pitman arm and steering arm to get the modern style draglink with taper seat bolts.
Also, when did self adjust brakes first appear on GM trucks?
Keith
1964 was first year for self adjust brakes on chevys as far as i know.
Self adjusters may have come later, but Bendix brakes started on the 3600 either 51 or 53 (can't remember which) and they can be retrofit to your axle.
Not certain about trucks but some chevy cars used the self adjusters on bendix brakes starting in 1963.
Well, I failed to ask if the 1953 or 1954 Pitman arm and steering arm would work on my 1948 3600. I assume the 1/2 ton stuff is different?
Keith
