6 members (Jon G, klhansen, dt235sd, Tim Canfield, Oswald, 1 invisible), 92 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#691419 11/03/2010 1:31 AM
I have a "54" 3100 pickup and when I look at it from the rear the cab is leaning to the left. When I look under the truck the shackle on the right side appears to be standing up better than the shackle on the left side I notice there are rubber bushings in these shackles could it be as simple as worn bushing when I measure it is a good 1/2" - 3/4" difference from the frame to the cab from one side to the other? Any sugestions, what else can I check?
Mike
mperk #691426 11/03/2010 1:55 AM
Take a look at the left and right cab floor supports also
http://www.classicparts.com/1947-54-Front-Cab-Floor-Support-Left/productinfo/45-411/
Sometimes they collapse if heavily corroded
pic
Good Luck
mperk #691428 11/03/2010 1:56 AM
Sounds typical. These trucks (much like Jeeps) were generally driven by one person with no passengers. Over a long period of time the uneven wear becomes visible.
chicklin #691454 11/03/2010 3:13 AM
I have found the part in question in the factory assembly manual it is called the "body mounting shackle" has anyone replaced the bushing in this part to level the cab I also see that there is a shim where the shackle attaches to the cab to hold a distance of .76 between the cab and the frame I do not have that gap so I guess I will check the shims and see what is there?
mperk #691478 11/03/2010 4:32 AM
Y
Y Offline
Now would be a good time to check all (4) cab mounts. If the front mounts are loose it will let the cab move, especially when you set the park brake.
Yakimabowtie #691485 11/03/2010 4:41 AM
~Jim
I posted only one link, to American Classic Truck Parts, our sponsor here. However most vendors carry these parts.
~Jim
If the rear of your cab is in good shape, the angle is determined by what is happening at the front mounts. This is how the shackle system works. The shackles do not contribute to the cab sitting level and this allows the frame to move without twisting the cab.
1951 1 Ton Completed
mperk #691560 11/03/2010 2:24 PM
When I bought my 50 3600 I too noticed the cab had a slight "lean". Turns out the front cab mounts were rusted through and could no longer support the weight of the cab. The PO had jammed pieces of 2x6 lumber between the cab and frame to support it.
I ended up pulling the cab off and welding in new mounts.
Here's a pic:
http://i671.photobucket.com/albums/...0%20Chevy%20Truck%20Project/Pict0525.jpg
