2 members (carbking, TUTS 59), 108 guests, and 2 robots.
Topics128,029
Posts1,055,416
Members48,422
#690944 11/01/2010 1:05 PM
I have several broken wheel studs on my '48 rear axle, and have tried hammering with a large hammer, and drilling a hole thru the center, no luck. Is it safe to heat the flange somewhat to help drive these studs out? Understand that too much heat may damage axle seal.
Usually they are not that difficult to remove. I use a nut in place and a big heavy hammer to place a slow blow. If you have to resort to drilling, you may want to heat the stud a bit and let it cool naturally. That may soften it up a little.
1951 1 Ton Completed
I'd try and fit a block of wood between the back side of the axle and the flange that the backing plate bolts to. I will make things a bit more firm while your pounding the stud out.
The above techniques usually work but I was not able safely remove the studs by hammering. If you have a study C (or D) clamp you might be able to rig a device like this. This can also be used to safely install the new studs.
They may not usually be this tough, but these are not moving!! Drilled out all but about 1/16" and still will not hammer out. May have to drill the entire stud material out. Had to really hit the front drum studs hard with a BIG hammer to get them out!!
Plan B...I have another '48 third member complete, with good studs all around. How hard is it to pull axles out of this rear end and replace the ones in my truck?
You neglected to say they were the rear studs. Ir is easier to pull the axle and work on a bench vice.
Get one of these[a ball joint remover/installer]. I just bought one for $25. Works great for many things on these old trucks.
Bruce
My Trucks
Stuff I Collect
gazim
Is it a difficult procedure to pull these axles?
No.
The instructions in the Shop Manual are clear and fairly easy to follow.
