8 members (PAUL Berardi, Phak1, DaveV, Cheapskate1229, Otto Skorzeny, carbking, Peggy M, Wayne67vert),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | I've seen several different styles of either repro's or original that say they are the real thing. Not sure what fits, may have to make my own, using the stock bumper (same as the front) Found some in a yard from a 39 - will they fit frame and bumper or should I just make my own?
ETA: Already STFA
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | I made my own rears for the '37, it was pretty easy to bend them to fit. Only draw back is, they are soft and will bend very easy if hit. The stock brackets have some spring steel in them. Maybe you get yours heat treated or something if you bend up a set. The aftermarket ones may be just soft steel anyway, so it might not matter. Also, if you bend you own, you won't have the GM logo in the steel like the OEM ones do.
Joe | | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | Joe,
Your truck is entirely way too cool.
