BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
11 members (RBs36, 2-Ton, Charles in CA, Wally / Montana, TUTS 59, Shaffer's1950, JW51, 46 Texaco, niobrarafun, MikeE, Ponchogl),
549
robot. | Key: Admin,
Mod | | Forums66 Topics126,776 Posts1,039,277 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Oct 2009 Posts: 201 Shop Shark | Shop Shark Joined: Oct 2009 Posts: 201 | I've seen several different styles of either repro's or original that say they are the real thing. Not sure what fits, may have to make my own, using the stock bumper (same as the front) Found some in a yard from a 39 - will they fit frame and bumper or should I just make my own?
ETA: Already STFA
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | Joined: Feb 2000 Posts: 4,886 'Bolter | 'Bolter Joined: Feb 2000 Posts: 4,886 | I made my own rears for the '37, it was pretty easy to bend them to fit. Only draw back is, they are soft and will bend very easy if hit. The stock brackets have some spring steel in them. Maybe you get yours heat treated or something if you bend up a set. The aftermarket ones may be just soft steel anyway, so it might not matter. Also, if you bend you own, you won't have the GM logo in the steel like the OEM ones do.
Joe | | | | Joined: Oct 2009 Posts: 201 Shop Shark | Shop Shark Joined: Oct 2009 Posts: 201 | Joe,
Your truck is entirely way too cool.
