1 members (Otto Skorzeny), 81 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#690603 10/31/2010 3:08 AM
Does anybody know how I could tell if a radiator is for a Task Force V8? I acquired a used radiator; the seller said it was from a V8 truck. My stock radiator (1957 Chevy, 3/4 ton, six cylinder)is about 3/4 of an inch wider and an 1/2 inch thinner than the purported V8 radiator. My new engine is a 283, I haven't figured out the shroud issue yet.
Don
Donsz #690630 10/31/2010 4:34 AM
the rads for the 6 and 8 are the same, just mounted different [V8 rad further back] - I believe there was a heavy duty version tho, which would be different in thickness - but if the rad isn't the same width as yours it isn't for a 5-7 Chev as the core supports are all the same - may be from a GMC, which were slightly different dimensions
squeeze #690717 10/31/2010 4:23 PM
Thanks Bill. That helps.
Don
Donsz #690731 10/31/2010 5:50 PM
If you can find the original dimensions check with www.rockauto.com I bought a new copper radiator from them for $175.00 including freight (3 row wtrans cooler ) Looks just like the old one and fits right in the same place. Kieth
66 GMC SWB
65 Chevy LWB
65 GMC SWB
918-446-2245
