2 members (Materman, 1 invisible), 111 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#690637 10/31/2010 4:55 AM
1 Offline
I was just wondering if anyone could give me a brief explanation on how to replace the original mechanical fuel pump on a '53 3100 1/2 ton pickup.
I've never done this before, and just don't want to screw up. A simple step by step explanation would be great. (don't assume that I know much, because I don't)
I've had the tuck just 1 month, and it didn't want to start a couple days ago. It started for a minute, then acted like it had no fuel.
I towed it up through the pasture backwards to my house by myself with a Honda accord! (Thankfully there was no chance of anyone seeing that spectacle)
I have plenty of gas.I opened the Carter fuel filter by the carb and it looked clean. I'm guessing it is the fuel pump. I saw a new fuel pump w/ gasket at Autozone for $40. Should that be a good one or is there a better brand?
What is the correct way to stop the fuel when disconnecting the fuel lines from the pump? I spilled gas in the pasture last time I started to take it off.
Is it a good idea to replace the fuel lines at the same time if they look old? (truck was from the coast so it does have some rust issues)
Thanks in advance for any help. I'm determined to fix this first problem by myself. I was going to go buy a new fuel pump on Monday.
You might want to check your fuel tank for rust in it first ? Under the cab is a drain valve below the tank,you can remove the line if the valve wont work to drain the fuel. I would check that before replacing parts.
HOW TO LINK FOR YOU ALSO.
http://autorepair.about.com/library/diy/bl_fuelpump.htm
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
You also might think about getting a dual action pump if you plan to keep the vacuum wipers, Auto zone also sell those at about 79.00. i have one on my 54/3100. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
1 Offline
Thanks for the link and advice on the other fuel pump w/ vacuum. Thanks for taking time to help. Will let you know how it goes. Can't wait to get it running again!
