| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 6 New Guy | | New Guy Joined: Sep 2010 Posts: 6 | I was just wondering if anyone could give me a brief explanation on how to replace the original mechanical fuel pump on a '53 3100 1/2 ton pickup.
I've never done this before, and just don't want to screw up. A simple step by step explanation would be great. (don't assume that I know much, because I don't)
I've had the tuck just 1 month, and it didn't want to start a couple days ago. It started for a minute, then acted like it had no fuel.
I towed it up through the pasture backwards to my house by myself with a Honda accord! (Thankfully there was no chance of anyone seeing that spectacle)
I have plenty of gas.I opened the Carter fuel filter by the carb and it looked clean. I'm guessing it is the fuel pump. I saw a new fuel pump w/ gasket at Autozone for $40. Should that be a good one or is there a better brand?
What is the correct way to stop the fuel when disconnecting the fuel lines from the pump? I spilled gas in the pasture last time I started to take it off.
Is it a good idea to replace the fuel lines at the same time if they look old? (truck was from the coast so it does have some rust issues)
Thanks in advance for any help. I'm determined to fix this first problem by myself. I was going to go buy a new fuel pump on Monday.
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | You might want to check your fuel tank for rust in it first ? Under the cab is a drain valve below the tank,you can remove the line if the valve wont work to drain the fuel. I would check that before replacing parts. HOW TO LINK FOR YOU ALSO. http://autorepair.about.com/library/diy/bl_fuelpump.htm
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | You also might think about getting a dual action pump if you plan to keep the vacuum wipers, Auto zone also sell those at about 79.00. i have one on my 54/3100. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2010 Posts: 6 New Guy | | New Guy Joined: Sep 2010 Posts: 6 | Thanks for the link and advice on the other fuel pump w/ vacuum. Thanks for taking time to help. Will let you know how it goes. Can't wait to get it running again! | | |
