10 members (Otto Skorzeny, carbking, 55shaker, fonz8261, Greg_H, Hotrod Lincoln, Cletus1950, Peggy M, 2 invisible),
148
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,721 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69058 11/23/2006 4:35 PM | Joined: Nov 2005 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 49 | Has anyone ever attempted this? I have tried to search for this, but all the info was with the engine out of the vehicle. I know that the engine will have to be safely supported while this is going on. Yup, I am doing the T5 thing also and am still debating whether to go the bellhousing exchange route or adapter plate.
Thanks, Brian | | |
#69059 11/23/2006 6:03 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It can be removed with the engine in the truck. Pull the trans. & clutch first. What year are you working on? The T-5 fits most bell housings. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#69060 11/23/2006 6:17 PM | Joined: Nov 2005 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 49 | I have'nt taken a real close look at this endeavor yet. Still in process of gathering necessary parts. The truck, [1940 1/2 ton] is located out of town. I know the old saying, anything can be done with enough time and [money].
Thanks again, Brian | | |
#69061 11/23/2006 6:25 PM | Joined: Nov 2005 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 49 | Forgot to mention that the bellhousing has to be changed up to a '48-'54 and the pedal mount has to be fabricated onto the housing. '47 and prior housings don't have the correct size hole and transmission mounting holes are in a different location.
Brian | | |
#69062 11/23/2006 6:40 PM | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I might be slow, but whats a T5? | | |
#69063 11/23/2006 6:54 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#69064 11/23/2006 7:51 PM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Brian, It must be eazier to use an adapter plate on your bellhousing and retain the pedal mounts. The t-5 has a longer input shaft which makes extra work in trying to adapt it without an adapter plate. Cavebull and Steppinwood both have excellent photo documentation of this conversion.
I also have a 1940 (GMC) I had an adapter plate made for me out of 6066 aluminum at a local machine shop. It is a relatively simple job. I will be using a NV4500 transmission instead of a t-5. In hind sight the T-5 seems like a more appropriate swap. The NV4500 is much bigger and wider than the stock transmission and the t-5. I still might have to come up with a system for mounting the clutch and brake pedals.
The advantages of the NV4500 are it is stronger, it has the same splines as a stock transmission, it was new, it has both a granny low gear and an overdrive. Disadvantages include the size and the cost. | | |
#69065 11/23/2006 8:28 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | As stated, this adaptor is the only sane way to go with your year truck. Moves the T-5 back just enough as to not interfere with clutch disc, plus you need the master cyl mount of the original bell housing. Check with Buffalo Ent, runs an ad on inliners.org. | | |
#69066 11/23/2006 8:56 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Brian - I just completed the installation of a T-5 in my 37 pickup. I would highly suggest you go the adapter plate route. It is much easier - you won't have to shorten the transmission input shaft and you won't have to lengthen the splines on the input shaft. Mine worked out great! The one thing I don't like about the later bell housing is the fact that the mounts have to be welded on for the brake-clutch pedal and master cylinder bracket. I have never been comfortable with welding cast iron, especialy steel to cast iron and when it comes to the brakes and clutch, I would try to avoid this sort of welding activity. I think you are much, much better off with the original bell housing and the use of an adapter plate. Of all the advantages, the biggest is that you wouldn't have to pull the bell housing from your truck, a job that I see as a pretty good size chore. Probably the easiest way to pull the bell housing would be to pull the engine, which to me means pulling the front sheet metal. Allot of work to avoid a safe and sensible transmission adapter plate. Just my 2 sense! Good luck, Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#69067 11/23/2006 10:26 PM | Joined: Nov 2005 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 49 | Thanks for the replies everyone. I think I will go with an adapter even though I do have a bellhousing rounded up. I do not want to create anymore work for myself than I need to. I had been following Steppenwood's, cavebull's and your conversion, Joe and it sure does look to be the cleaner and more sane way of doing this. Excellent workmanship you guys. I will look into ordering an adapter or taking my own measurments and try to get one made up here.
#69068 11/24/2006 4:08 AM | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | I'm toying with the idea of changing the trans and rear end in my '40 GMC also. If an adapter plate is used with a T-5 conversion, is the stock pilot bushing used or do you need an extended bushing? I just put a rebuilt 235 in my truck last year and installed a new pilot bushing, so I'd rather not have to change it in the truck if I don't have to.
Thanks, Steve | | |
#69069 11/24/2006 6:02 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I didn't install a new pilot bearing in my 37. I had also installed a new one not too long ago and found that the input shaft "snoot" was exactly the same diameter dimension on the T-5 as the input shaft "snoot" on the stock transmission. The "snoot" was longer on the T-5 and that was exactly what I needed to make the installation work correctly with a 1/2" thick adapter plate. I would think the GMC would be the same. Joe
#69070 11/24/2006 1:49 PM | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | Thanks Joe. I've read the tech articles, but I'm sure I'll have more questions if I decide to go this route. Thanks, Steve | | |
