0 members (),
89
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Does anybody know how I could tell if a radiator is for a Task Force V8? I acquired a used radiator; the seller said it was from a V8 truck. My stock radiator (1957 Chevy, 3/4 ton, six cylinder)is about 3/4 of an inch wider and an 1/2 inch thinner than the purported V8 radiator. My new engine is a 283, I haven't figured out the shroud issue yet. Thanks, Don
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the rads for the 6 and 8 are the same, just mounted different [V8 rad further back] - I believe there was a heavy duty version tho, which would be different in thickness - but if the rad isn't the same width as yours it isn't for a 5-7 Chev as the core supports are all the same - may be from a GMC, which were slightly different dimensions
Bill | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Thanks Bill. That helps. Don
| | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | If you can find the original dimensions check with www.rockauto.com I bought a new copper radiator from them for $175.00 including freight (3 row wtrans cooler ) Looks just like the old one and fits right in the same place. Kieth
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
