5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#685517 10/13/2010 12:57 AM
Hi,
I was hoping someone has an SM420 laying around and could measure from the front of transmission to centerline of shift tower.
My SM465 measures 5 1/2".
The SM420 is 10 1/2" overall, and the SM465 is 12"long.
(http://advanceadapters.com/resources/964/Manual-Transmissions.html)
Just trying to get an idea of shifter hole location with added length of OD unit.
Thanks.
Pete
64 Pete #685527 10/13/2010 1:12 AM
Pete
Have one in the shop - can measure it tomorrow.
What is the OD unit?
TIA
Dennis
TIA
Dennis,
I'll be using one of these Overdrives from Advance Adapters.
Goes between Bellhousing and transmission.
Moves everything back 7 3/8"
(they say 7 1/2")
see:
http://advanceadapters.com/product/1941/760002M-27.html
Note:
Cheaper thru Summit
Pete
64 Pete #685749 10/13/2010 4:43 PM
Thanks.
Would this be cheaper and easier than rear gears from Patrick's?
It shows to be 80 pounds. Would a brace be needed?
And the shifter would be pushed back. Are you going to modify the shifter or simply have the shifter closer to the seat?
Thanks for the information.
Dennis
Thanks.
Q. Would this be cheaper and easier than rear gears from Patrick's?
I have a 1 ton so I'm not going to find gears too easily.
Q. It shows to be 80 pounds. Would a brace be needed?
Advance Adapters advised going to a crossmemnber and avoid the bellhousing mount.
Q. And the shifter would be pushed back. Are you going to modify the shifter or simply have the shifter closer to the seat?
Truck will have separate seats but probably still need to do something to lever.
Sorry this took so long.
64 Pete #689651 10/27/2010 6:26 PM
Thanks for the reply.
I wish you the best with your project
Dennis
4 1/2 inches back from the bellhousing.
Thanks for the measurement.
Looks just swapping the SM-465 in place of a 420 moves lever back 1", plus the 7 1/2" for the OD unit.
Now I'll have to see how putting in a 292 effects driveline location.
Pete
"Measure several times, cut once. I hope!"
64 Pete #690492 10/30/2010 3:51 PM
I followed the link to the advance site. Very interesting item. At 27% reduction that's a nice O/D. I did not see the price on that page. How do I see the price? I also saw that they are saying out of stock until 12-1-10. Do they offer that with the smaller bearing retainer to fit in front of a SM-420?
Good luck. Keep us informed about how this works in your Panel truck. Oh, and pictures! We love pictures.
Professional Novice
Frank50 #693031 11/08/2010 7:37 AM
Excellent, You've inspired me!
Been looking to do same. Several months back, I snagged a Power Torque Industries cast iron version of this OD unit with thought of also placing in front of my SM420. I have the add'l task of re-swapping back in my 3.90 ring/pinion.
How did you go about modding the driveshaft?
1960 Chevrolet Apache 10 Short Fleet black
1995 Chevrolet Silverado 1500 Z71 RCSS black
1963 Oldsmobile Starfire Coupe black/black
1965 Oldsmobile Starfire Convertible teal
1965 Oldsmobile Starfire Convertible white
1965 Oldsmobile Dynamic 88 Convertible sand
1965 Oldsmobile Dynamic 88 Convertible red
