3 members (Otto Skorzeny, KEVINSKI, Hotrod Lincoln), 94 guests, and 4 robots.
Topics128,099
Posts1,056,506
Members48,444
Hi there group I have a 53 1 ton Truck with a Williams machine & tool Co. pump model 800. does any one have this pump and where can some one get parts seals etc for it. Please help
Gerry
1953 1-Ton Canadian Model 1434
More pix on Photobucket
Dave
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showprofile&User=3963
may have some answerers or suggestions, wait for him to chime in.
In the meantime, if it's just regular parts, bearings, seals and such take them in or the dimensions to NAPA and see what they can find.
Seals are usually not that hard to find by the part number stamped on them or by the dimensions.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Williams is still around and supplies a lot of hydraulics to agriculture equipment. You might give them a call and see if they still have old books. http://www.energymfg.com/williams-manufacturing/
Williams pumps are piston type pumps, your 800 series is an 8 piston model. NONE of them regardless of 2, 4 or 8 piston will withstand over 1000 RPM or continuous usage or they will come unwound. They can develop 3000+ psi and often are seen with a control valve located on to[p of the oil reservoir. I think it is still a current model. The PRM restriction is why they are not used on highway trucks. It is fine for the old type scissor hoists, etc seen on farm trucks. In all likelyhood they will sell parts direct. Keep this pump clean!
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
