3 members (tclederman, Donf, 1 invisible),
71
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 66 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 66 | I went out to drive the '60 panel- truck this morning.I put the key in the ignition,and....wouldn't turn at all.I messed with it for quite a while,but it still wouldn't budge. Then I got the bright idea of removing the switch from the dash.I started unscrewing the piece that held it in place,but it got to where it wouldn't keep unscrewing. What should I do?What am I doing wrong?
- Doug | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | You may need an ignition switch removal tool like my 57' Chev requires. You may be able to remove the tumbler by inserting a paper clip wire into the small hole on the face. | | | | | Joined: Aug 2010 Posts: 66 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 66 | Mine has the hole that you can put a paperclip into,but you have to turn the key to get it to release. I finally got it out,but I had to pry the outside housing nut off to get to it.Now I'll have to replace the lock assembly.
- Doug
