1 members (delky), 74 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,422
#690171 10/29/2010 2:25 PM
I have come across a 235 that I want to use in place of the 216 that is currently in my 37 1/2 ton.
Here are the numbers off the 235:
Head 3835913
Block 3764476
Is this a good swap or am I looking at a lot of messing around to make things work.
I currently have the standard 3 speed and rear end in the truck but those are on the list to upgrade next once I find what I need for that project.
That's a '58-'62 235 and would be an excellent upgrade. I don't have experience with a '37, but it's common to swap those engines. Remove the front engine plate on the 216 and replace the 235 front plate with it. It'll make the swap pretty easy. You should have no trouble bolting everything together. Check the Tech Tips pages for additional help.
Drew
DrewP #690314 10/29/2010 10:47 PM
the back of the Patrick's catalog (inside the back, last few pages) show: how to swap a 216 and 235, step by step. I think its the same as the tech tip, but if you've got their catalog, you've got the instructions.
'53 Chevy 3604 Five Window Cab ('56 235)
DrewP #690320 10/29/2010 11:17 PM
Swapping the front plate requires disassembly of the valve train and camshaft removal. Drilling the mount holes in the existing plate is waaaaayyyy easier IMO. See the tech tips for a template.
You Tube
