3 members (Peggy M, Joe H, Wayne67vert), 52 guests, and 2 robots.
Topics128,026
Posts1,055,402
Members48,422
#686540 10/16/2010 1:05 AM
Hi
I'm new to all of this and just purchased a 1950 Chevy truck I haven't received it yet but I'm trying to id what engine is in it
http://classiccars.com/Classifieds/...74FEEBABC344333E3C3055F0CB4044&cs=11
any help would be appreciated
Fixer
Most likely it is a 216, unless the engine had been "upgraded" to a low-pressure 235. Here are locations of casting and ID codes. Post what you find and people will help ID what you have.
Welcome to Stovebolt.com
Is that filler cap really in the center of the valve cover? I have never seen that before on these covers.
1951 1 Ton Completed
That's what throwing me off I haven't found any pics with it there.
I may just have to wait and see when it arrives.
I have a 1943 Military splash 235 with one of those valve covers.
My Blog
this may help i don't know, take a look at some of the pics it may help http://pugetsoundvintagechevrolet.org/Programs/6%20cylinder%20engines%20with%20photos.pdf
Drive with Pride. mike j
family pic
Hey dakota, where did you find this link? I wanted to correct #5 pic. Thanks, Dave
My Blog
someone had posted it a while back. don't know who's site it is, guess you would have to look around on it for a contact number. did you figure out the engine you have, seen another post that has some good info you can check.
family pic
Above engine link comes from this site I believe
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
well I still haven't found a cover that is like mine.I found covers that the oil fill is in the center but then it doesn't have the stud holes. I did get the truck a couple of days ago it's a 3/4 ton.
The engine code is HAA364772
I believe it is a 216 from a passenger car.
correct me if I,m wrong
the next question I will it make a difference when I order parts?
thank for your help I'm sure I'll need a lot more
Your cover is not a standard production item. As I stated above, I have one on a 1943 military engine. That is the only place I have seen this cover used.
Here is a link to all the standard production 216 and 235 covers Chev used.
I show "HAA" code as a 1950 216.
My Blog
When I order parts is the HAA code something they need?
since it's not the original engine
The HAA only meant something to GM production. Just calling it a 1950 216 should get you anything you need.
My Blog
-Tom
1950 Chevy 3100 w/ 1956 235
In the current issue of the VCCA magazine "Generator and Distributor, there is a description of a valve cover and cap with a filter in the middle of the cover. It is described as a special item that was made available in 1941 for operation in dusty driving conditions.
