9 members (Tronman, tclederman, Bill Hanlon, Otto Skorzeny, Hotrod Lincoln, carbking, 49choptop, Guitplayer, John L.),
145
Mod | | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Most likely it is a 216, unless the engine had been "upgraded" to a low-pressure 235. Here are locations of casting and ID codes. Post what you find and people will help ID what you have. Welcome to Stovebolt.com | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Is that filler cap really in the center of the valve cover? I have never seen that before on these covers. | | | | | Joined: Oct 2010 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 44 | That's what throwing me off I haven't found any pics with it there.
I may just have to wait and see when it arrives.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have a 1943 Military splash 235 with one of those valve covers.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Hey dakota, where did you find this link? I wanted to correct #5 pic. Thanks, Dave
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | someone had posted it a while back. don't know who's site it is, guess you would have to look around on it for a contact number. did you figure out the engine you have, seen another post that has some good info you can check. | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Above engine link comes from this site I believe http://pugetsoundvintagechevrolet.org/
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Oct 2010 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 44 | well I still haven't found a cover that is like mine.I found covers that the oil fill is in the center but then it doesn't have the stud holes. I did get the truck a couple of days ago it's a 3/4 ton. The engine code is HAA364772 I believe it is a 216 from a passenger car.
correct me if I,m wrong
the next question I will it make a difference when I order parts?
thank for your help I'm sure I'll need a lot more John
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Your cover is not a standard production item. As I stated above, I have one on a 1943 military engine. That is the only place I have seen this cover used. Here is a link to all the standard production 216 and 235 covers Chev used. I show "HAA" code as a 1950 216.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2010 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 44 | When I order parts is the HAA code something they need?
since it's not the original engine
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The HAA only meant something to GM production. Just calling it a 1950 216 should get you anything you need.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 |
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | In the current issue of the VCCA magazine "Generator and Distributor, there is a description of a valve cover and cap with a filter in the middle of the cover. It is described as a special item that was made available in 1941 for operation in dusty driving conditions.
