| | | Forums66 Topics128,257 Posts1,058,017 Members48,479 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 | I found a 1960 Chevy 1/2 ton panel wagon that I can pick up for free. Its pretty rusted out but the drivetrain is all there and looks to be in good shape. Would this be a good candidate for swapping out the torque tube on my 1953 chevy 1/2 ton. Does anyone know what gear ratio this might have? It has a 235ci and the transmission looks to be a 3 speed on the column. I'm looking for something fairly simple that would work. Its not a leaf spring setup but rather it has control arms. Thanks for your help.
1953 3100 Chevy 5 window 1971 Chevelle SS
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Probably a 3.90. Not much improvement from your 4.11. | | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 | Ok, thanks, right now I'm more interested in converting to an open drive shaft and something that is pretty easy. Later I can change the gears or tranny to improve the drivability.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I used a 79 nova rear end. did it my self and i am not very handy. drove it for 15 years before i had it professionally redone. the ratio is 2.73 but there are others. it does ok on flat land in fifth gear but on long up hills i have to use fourth if i have the cruise control on.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
