2 members (Hotrod Lincoln, Tronman), 167 guests, and 3 robots.
Topics128,257
Posts1,058,017
Members48,479
1 Offline
I found a 1960 Chevy 1/2 ton panel wagon that I can pick up for free. Its pretty rusted out but the drivetrain is all there and looks to be in good shape. Would this be a good candidate for swapping out the torque tube on my 1953 chevy 1/2 ton. Does anyone know what gear ratio this might have? It has a 235ci and the transmission looks to be a 3 speed on the column. I'm looking for something fairly simple that would work. Its not a leaf spring setup but rather it has control arms. Thanks for your help.
1953 3100 Chevy 5 window
1971 Chevelle SS
Probably a 3.90. Not much improvement from your 4.11.
1 Offline
Ok, thanks, right now I'm more interested in converting to an open drive shaft and something that is pretty easy. Later I can change the gears or tranny to improve the drivability.
1971 Chevelle SS
I used a 79 nova rear end. did it my self and i am not very handy. drove it for 15 years before i had it professionally redone. the ratio is 2.73 but there are others. it does ok on flat land in fifth gear but on long up hills i have to use fourth if i have the cruise control on.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
