7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,068 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68919 11/20/2006 7:17 PM | Joined: Jun 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 46 | I swapped the 3 speed on the column out to the floor shifted SM420 4 speed tranmission, everything bolted right back into place just like the 3 speed was, including the mount at the torque tube ball (rear transmission mount).
Now i'm working on changing the old enclosed driveshaft & rearend out to a open driveshaft & newer rearend (better gear ratio), my question is this, on our trucks, that had the open driveshafts & 4 speed (SM420) is there a rear transmission mount? By looking in the manual that I got from Chevrolet, there appears to be either a 4 point mount (motor & transmission), or a 3 point mount (motor only). So is it safe to think that the 4 speed did not have a rear mount.
Thanks | | |
#68920 11/20/2006 9:41 PM | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | for most trucks that have the 4spd tranny and aren't 4x4 it pretty much just has 2 engine mounts (one on each side) and another 2 mounts on the bellhousing for the tranny and no mounts for the rear/tailshaft my 55 2nd series, 70 chevys are this way also my 64 chevy with 3spd was the same Nate | | |
#68921 11/20/2006 9:47 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | No rear mount on mine. I installed an O.D. a few months back and concerned about the extra weight, I added a new crossmember mount to the adapter between the transmissions. | | |
#68922 11/21/2006 2:18 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My 51 1 Ton has one front engine mount and two side mounts on the nell housing. It has the 4 speed and the open driveshaft. | | |
