0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
#68919 11/20/2006 7:17 PM
I swapped the 3 speed on the column out to the floor shifted SM420 4 speed tranmission, everything bolted right back into place just like the 3 speed was, including the mount at the torque tube ball (rear transmission mount).
Now i'm working on changing the old enclosed driveshaft & rearend out to a open driveshaft & newer rearend (better gear ratio), my question is this, on our trucks, that had the open driveshafts & 4 speed (SM420) is there a rear transmission mount? By looking in the manual that I got from Chevrolet, there appears to be either a 4 point mount (motor & transmission), or a 3 point mount (motor only). So is it safe to think that the 4 speed did not have a rear mount.
#68920 11/20/2006 9:41 PM
for most trucks that have the 4spd tranny and aren't 4x4 it pretty much just has 2 engine mounts (one on each side) and another 2 mounts on the bellhousing for the tranny and no mounts for the rear/tailshaft my 55 2nd series, 70 chevys are this way also my 64 chevy with 3spd was the same
Nate
Link to my photobucket for pics of my vehicles
http://s238.photobucket.com/albums/ff17/OldIronChevy/
#68921 11/20/2006 9:47 PM
No rear mount on mine. I installed an O.D. a few months back and concerned about the extra weight, I added a new crossmember mount to the adapter between the transmissions.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#68922 11/21/2006 2:18 AM
My 51 1 Ton has one front engine mount and two side mounts on the nell housing. It has the 4 speed and the open driveshaft.
1951 1 Ton Completed
