7 members (1955 1 Series, Wayne67vert, Brian Moore, Jon G, KEVINSKI, 50Chevy3100, 1 invisible),
50
10
Mod | | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 32 New Guy | | New Guy Joined: Jun 2010 Posts: 32 | I haven't installed my ignition switch yet. I have the switch and the tumbler that has the key. When I put the two together, should it fit in there flush and the key turn? Mine doesnt. It all looks like it should line up and seat in there, but it doesn't. I have had a couple of guys who know a thing or two about these trucks tell me it should, but it's not. I have even gotten a different ignition switch, and I'm now contemplating sending my tumbler with the key back and see if that's the problem. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The tumbler should be resonably flush with the switch. The dash retaining collar that holds the switch in place should definitely be flush when installed. You should not be inserting the tumbler into the switch without the key in the tumbler.
Drew
| | | | | Joined: Jun 2010 Posts: 32 New Guy | | New Guy Joined: Jun 2010 Posts: 32 | I've got the key in there when I insert it, but the key won't turn. Is it supposed to? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The key should be turned counter clock wise after you insert the the tumbler into the switch housing. That locks the tumbler into the switch housing. After that the key should turn normally clockwise as if you are turning the ignition on.
Drew
