| | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | I was wondering if anyone could help me concerning the wiring going to the starter on a 55 2nd series with the original 235 motor and 3 speed tranny. The starter is the original starter set up with the foot stomp button. I have been using the factory assembly manual to do most of the wiring but it is not to clear when it comes to wiring the starter. I have the battery and amp guage wire attached to the top of the starter switch. But I can not figure out where the wire goes that comes off the side of the starter switch. From what I can figure this wire goes to the resistor and drops the voltage when the engine is running. Does anyone happen to know how the starter is wired up ? A picture would really help, thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | that wire goes to the the ignition switch - follow colors - it actually increases the coil voltage, when starting, as it bypasses the resistor which normally gets voltage from the ign sw when running Bill | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy guys, my assembly manual shows a dark green wire going from the small terminal on the starter foot switch directly to the coil positive terminal. The drawing is in section 12 sheet 5. squeeze, I think that ignition switch picture is of a key start switch, hope that helps. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You are correct Bobb. Sixes and V8s were wired differently. A six cylinder switch does not have the start position. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 6 cyl switch wiring - V8 switch wiring ... they both came off factory wiring diagrams, works on the trucks I've had if the resistor bypass wire went directly from the starter to the coil the truck would fire whenever the foot stomp was depressed regardless if the key was on or off, pretty dicey situation .... with proper wiring the coil only gets power from the ign switch, either from the resistor or the starter Bill | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | Thanks for all your help on the starter wiring. I have it wired up and working. The picture squeeze had helped a great deal.
