4 members (MickeyP, TexasA&M48Truck, walter74, cmayna), 42 guests, and 4 robots.
Topics128,012
Posts1,055,321
Members48,419
#68814 11/19/2006 3:09 AM
So i`m thinking of rebuilding the free 250 six i was given I have thoughts of replacing the 305/th400/Doug-nash overdrive in my 1981 shortbed,stepside p.u. with it. Actually i want the 250/700r4 combination. So my questions are this 1) Has anyone put together the correct part numbers to do a quality rebuild? Not just the numbers for carbs, intakes, exhaust? 2) 307 pistons, (0.30 work?)3)Do we know the best size valves to install? Part number? 4)What bearing seem to work better in these 6 bangers?5) How about part numbers for cams?And cam brands?6) what do you fella`s thinks about balanceing the 6 bangers? 7) is there an after market harmonic balancer (part number) that you guys recommend?8) Although not intrested in rollor rockers, does anyone make roller tip rockers for the 250? I am hoping some of you have this stuff written down some where. If not would you be so kinda as to take a few minutes and respond with your choices. Let me say in closing i am not building a racer. Just good powerfull reliable 250. Thanks so much for your time this evening. And hea, Have a fun day tomorrow.
Slider
Jesus is Love! Never forget the Veteran.
AND God bless Amercia!
#68815 11/19/2006 3:28 PM
Like this? Slightly warmed, stock rebuild.
Cam Crane 203901
Lifters Rhoads RHL-8178 {KEM-817-4 old}
Rocker Arm Sealed Power R826
Piston TRW 403CP
Rings (moly) Sealed Power E234K
Main Brgs Federal Mogul 4124M
Rod Brgs Federal Mogul CB745P
Cam Brgs Clevite SH399S
Timing Gear Set Cloyes 2525S
Ignition Pertronix 1162A
PCV KEM PCV20
VC Plug Stant 10072
Breather Cap Stant 10064
Plugs NGK 7149, GR4IX {AC R44XLS}
Manifold Gasket Felpro MS9786
Valvecover gasket Felpro VS13173-1 (Cork Rubber)
Fan Belt Gates 7400
Water pump Cardone 58-405
Upper hose Gates 20698
Lower hose Gates 20145 with 26391 adapter
Air Cleaner Assy ~88 GM
Air Filter AC A178CW
Oil Filter WIX 51061
Double WP Pulley MrGasket 4971
Intake Manifold Offy 5416
Headers (cast) www.stoveboltengineco.com
Carb Edelbrock 1404 500cfm
Choke Kit Edelbrock 1478
carb kit Edelbrock 1477
Carb calib kit Edelbrock 1486
Fuel pump Carter P4070
Fuel reg Mallory 4309
Fuel press gauge Autometer 2178
Gas filter 3/8" inline ahead of pump, 3/8 post
#68816 11/19/2006 4:50 PM
That`s what was after. Spot on! Way cool !!! Yeah! Thank you Thank you. Do you have a build up article, that you have written? You know, your own how to? With picture? I have rebuilt many Chev v8`s. this will be my frist inline six. I am so stoked about it. Can`t thank you enough. Have a fun day today. I will . Go Seahawks.
#68817 11/19/2006 4:53 PM
Chuck the truck, thanks again. Are the Rocker arms by sealed power roller rockers or standard 1:75? thanks in advance.
Slider
