2 members (Gray_Ghost, Joe W), 211 guests, and 2 robots.
Topics128,108
Posts1,056,231
Members48,436
Today I was pricing paint for my engine. I used the PPG code 34560 I got from Tim's page. They quoted me $90 a quart for the good stuff and $25 for the cheap stuff. My question is, should I get the good stuff or will the cheap stuff last on an engine? What about hardner, do or should I use it?
Bruce
My Trucks
Stuff I Collect
Why not just get a pint? It certainly won't take anywhere near that much to paint an engine.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
The cheap stuff you are refering to is probably Omni? That's even cheap for a quart of Omni. Omni doesn't cover anywhere near as well as the DBU does. It seems like the better paints have more pigment in them.
DG
Denny G
Sandwich, IL
I've never done more than a rattle can in the past and I'm just begining to get experiment with the auto painting thing. Is a pint really enough to paint the whole engine and bell housing? What about the hardner, do I need it?
Bruce
My Trucks
Stuff I Collect
What line of PPG paint are you referring to (when you refer to adding a hardener)?
One of my how-to books says that if you're planning to use the vehicle as a driver, use the cheapest paint you can get because the good stuff doesn't last much longer on an engine that's being used. I haven't followed that advice myself though. I bought high-temp engine paint.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Willing to bet they quoted you single stage urethane DCC (high end) and the cheap stuff is AE or acrylic enamel (Omni).
Yes you need the hardener unless you dont want the paint to cure.
Currently working on custom metal and How to videos.
1949 and 1972 chevy trucks
70 chevelle SS455
Pictures of my work and projects
http://community.webshots.com/user/sevt_chevelle
You should use a hardener in an acrylic enamel (not the urethane, which is a two-part paint and has a catalyst).
I think a pint would do your engine and clutch housing.
Originally Posted by 55 1st suburban
Is a pint really enough to paint the whole engine and bell housing? What about the hardner, do I need it? Bruce
A pint, once reduced per instructions, is enough to cover your engine and bell housing and probably your entire driveline.
Yes, you will need reducer and hardener. Your paint dealer will set you up.
TIP: If you plan to paint your truck you should use the same brand paint for everything and save money on reducers and hardeners.
Woody
Door Art Collection
[/quote]
TIP: If you plan to paint your truck you should use the same brand paint for everything and save money on reducers and hardeners. [/quote]
Good advice!!
Bruce
My Trucks
Stuff I Collect
Another Bolter benefits from my mistakes (:
Woody
Door Art Collection
Czechman, you have so many good tips that I have had you on the watch list for 2 years....keep up the GOOD work
Brad
