4 members (klhansen, Nick in Manitou, Lightholder's Dad, 1 invisible), 86 guests, and 2 robots.
Topics128,049
Posts1,055,679
Hi all! Asking your indulgence in advance for my ignorance... still learning!
I need the complete rocker arm assembly for a 1955; my question is if I need to limit the search to only that model year, or if the engine changed significantly from prior years.
Serial no. OI535F55Z IIUC, this is a Flint 1955, may have come from an auto, standard trans? I can't figure out the 'OI'. Casting no. 3836233. What model years can I search for rocker arm assemblies? Must be rebuilt. Thanks in advance for any help! The engine now resides in my '50 3100, if that makes a difference.
Hey AbleMabel.
What kinda engine you got there? 235, etc?
Here's a great resource, thanks to Mr.Keith Hardy:
http://chevy.oldcarmanualproject.com
Good luck to you.
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
That O might be a 0 and would be part of the unit number (sequence number).
http://chevy.oldcarmanualproject.com/models/engine.htm#55eng
F55Z - second series 1955, standard 235 engine
3836233 = 1955 block casting code
IIUC = If I Understand Correctly
Hope that Pre '68 Dave will post information about rocker arm assemblies (over the years there were differences in the oil-feed path, and maybe in the rocker arms?).
1954-58 will be a direct replacement as an assembly.
The rocker arms and shafts are the same from 1950-58 on 235s.
The supports from 1950-53 are slightly different.
The rocker arms starting in 1959 have the oil groove inside the rocker offset, part of an oiling change, but will work OK, if setup correct, in a pinch.
My Blog
It's a Passenger car engine with manual trnasmission. Had it been a Truck engine, the code would come out as a '55 First, Second Series have 255 as the year code.
Bill Burmeister
You guys ROCK!
Thank you, thank you!
Now off to find an assembly.....
~ michelle
Well my Boy, we used to Rock "n Roll but mostly now a little foot tappin will do it!
dg
My Blog
