| | | Forums66 Topics128,056 Posts1,055,792 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 16 New Guy | | New Guy Joined: Sep 2009 Posts: 16 | Hi all! Asking your indulgence in advance for my ignorance... still learning!
I need the complete rocker arm assembly for a 1955; my question is if I need to limit the search to only that model year, or if the engine changed significantly from prior years.
Serial no. OI535F55Z IIUC, this is a Flint 1955, may have come from an auto, standard trans? I can't figure out the 'OI'. Casting no. 3836233. What model years can I search for rocker arm assemblies? Must be rebuilt. Thanks in advance for any help! The engine now resides in my '50 3100, if that makes a difference. | | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | Hey AbleMabel. What kinda engine you got there? 235, etc? Here's a great resource, thanks to Mr.Keith Hardy: http://chevy.oldcarmanualproject.comGood luck to you. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That O might be a 0 and would be part of the unit number (sequence number). http://chevy.oldcarmanualproject.com/models/engine.htm#55engF55Z - second series 1955, standard 235 engine 3836233 = 1955 block casting code IIUC = If I Understand Correctly Hope that Pre '68 Dave will post information about rocker arm assemblies (over the years there were differences in the oil-feed path, and maybe in the rocker arms?). | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1954-58 will be a direct replacement as an assembly.
The rocker arms and shafts are the same from 1950-58 on 235s.
The supports from 1950-53 are slightly different.
The rocker arms starting in 1959 have the oil groove inside the rocker offset, part of an oiling change, but will work OK, if setup correct, in a pinch.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | F55Z - second series 1955, standard 235 engine It's a Passenger car engine with manual trnasmission. Had it been a Truck engine, the code would come out as a '55 First, Second Series have 255 as the year code.
Bill Burmeister | | | | | Joined: Sep 2009 Posts: 16 New Guy | | New Guy Joined: Sep 2009 Posts: 16 | You guys ROCK!
Thank you, thank you!
Now off to find an assembly.....
~ michelle | | | | | Joined: Oct 2007 Posts: 84 New Guy | | New Guy Joined: Oct 2007 Posts: 84 | Well my Boy, we used to Rock "n Roll but mostly now a little foot tappin will do it! dg | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
