3 members (MickeyP, Bill Marlow, 48jim1ton), 114 guests, and 1 robot.
Topics128,049
Posts1,055,552
Members48,425
#68750 11/17/2006 12:21 AM
In an attempt to eek out more power from my 235, I had it bored over a bit, added a higher lift cam, installed dual intake and exhaust manifols and made the distributor electronic.
I would have enjoyed Patrick's SS exhaust to bolt to the dual Fenton's, but alas, they cannot be had.
So down to the local muffler shop. I would like to come off the dual manifold and down quickly into a merging collector then one pipe back to a FlowMaster Delta 50 muffler and one pipe out. Here's the question:What would be the best diameter pipes?
From the manifold, then just after the collector to the muffler, then out the muffler to the open end. 4 pipes total.
#68751 11/17/2006 1:00 AM
The 235 is not a high revver, so you'd be more than fine with 2" pipes. You could go bigger of course, so let's say 2 1/4". If you want to merge into a single exhaust, then don't make the single any less than 2 1/2". Personally, I'd keep it dual exhaust all the way back.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
#68752 11/17/2006 1:10 AM
Im with Hot Rod Dad,,theres nothin sweeter than twice pipes with glass packs!!
#68753 11/17/2006 1:54 AM
Once again, I may be biased, but I don't think you can beat the harmonics of dual pipes. Maybe you're trying to be quiet? I think it may end up sounding like a tuner - no offense - I think it will just have more of that sound with a single outlet.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#68754 11/17/2006 6:56 AM
bigmacdaddy, you lost me. Are you saying dual pipes all the way or a single in and a single out?
#68755 11/17/2006 5:44 PM
I think squeezing it back into one pipe defeats the purpose of the Fenton's. The local shop with a good bending guy can have all you done same day. You're really missing out on a cool sound if you don't have 2 pipes. Go with 2" if using 2 pipes.
Curt B.
You Tube
#68756 11/17/2006 11:01 PM
I'm pretty much saying exactly what I.B. Hoggin said. I think that "y" ing into a collector and a single pipe through a single muffler with a single tail pipe both defeats the purpose of the fentons AND might just make your truck sound like a tuner. I would like to hear it though - just to know!!! BTW The shop that did mine had it done in less than 3 hours and charged me $300.00 for 2" duals from the fentons and out the back. As you know, I provided the "dual in, dual out" muffler from Patricks.
My Webshot Photos]
#68757 11/18/2006 12:31 AM
What I don't want is the ol popping Smitty's sound when you let off the gas. Hooking up to dual glass paks might have that effect.
I contacted FlowMaster to dial in a 'sound'. They are the ones that suggested the Delta Series Muffler. And here's the real question...is Patrick's really a two in/two out? Or does it just 'mix' the dual in and provide the appearance of a dual out?
In other words; no net gain.
#68758 11/18/2006 1:16 AM
I have Smitty's on my 235 with fentons,, love the sound..sounds like they were suspose to sound back in the 50's..........never noticed a lot of popping when I let off the gas,, just a neat sound to me but........
hey cletis, dont it sound cool grin
Redryder pix
My Hotrod
#68759 11/18/2006 2:38 AM
Yes, it is a dual in, dual out, no mixing. I was told it had a built in crossover by someone who didn't know. I could clearly see it was 2 separate mufflers in one housing when I got the muffler. It was made by Bazani. It will last a lifetime - at least mine.
I had that "popping" sound during deceleration at first and I thought it was supposed to sound like that. Then my neighbor discovered that I'd left out the insulator gaskets when I replaced the carb. Now it's way smooth, no coughing and sputtering. A nice, clean and deep mellow sound. Quiet at lower RPMs.
My Webshot Photos]
