0 members (),
70
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 22 'Bolter | | 'Bolter Joined: May 2010 Posts: 22 | Working on my '51 and using a copy of the Factory Assembly Manual. Fasteners are called out and identified by numbers, such as Nut 441239 or Bolt 132900.
Does anybody have a list of what these #'s refer to or a source I can go to?
Thanks, great site.
Haasman
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Purchase a original or reprint of a Master Parts Catalog that is for the years that cover your Chevy. You won't find all the answers, but it helps. Also, use the site I linked. It's Larry's for his GMC, but non the less very helpful. http://www.laroke.com/larryk4674/2005/bbpartshp2.htm
Drew
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Larry's GMC? You must be referring to Deerslayer's 302 GMC (in a '37 Chevy truck)? BillyBob (the subject of the Nuts n Bolts information) is a 1955-1st series Chevrolet truck (which still has a Chevy engine, I think). The 1955-st series hardware list will be a little different from a list for a 1951 but still quite useful. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | "Does anybody have a list of what these #'s refer to or a source I can go to?" Bolt 132900 Round sloted head bolt (stove bolt), (machine screw) No. 10 - 32 x 3/8" SAE, Cad http://chevy.oldcarmanualproject.com/1929_54chevyparts/08/475.HTM
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Larry's GMC? You must be referring to Deerslayer's 302 GMC (in a '37 Chevy truck)? BillyBob (the subject of the Nuts n Bolts information) is a 1955-1st series Chevrolet truck (which still has a Chevy engine, I think). The 1955-st series hardware list will be a little different from a list for a 1951 but still quite useful.  Oops ! My bad.
Drew
