| | | Forums66 Topics128,179 Posts1,057,162 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68690 11/16/2006 3:40 AM | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | Is there any difference between a Truck and a car 6 cyl. stick bellhousing from say 55 through 62?Thanks everyone | | |
#68691 11/16/2006 4:26 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | yes.
Not sure what it is though. I believe it has something to do with the mounting or clutch linkage. All chevy 6 cylinder bellhousings are interchangeable from about 1937-1962. They also interchange with GMC from about 1939- 1959. That is to say any bellhousing from this era will bolt up to your engine. It may not necessarily bolt up to your transmission or chassis. Rule of thumb is to use the bellhousing that is correct for the year range and model... 1939- 1946 truck, 1947- 1954 truck, 1955-1959 truck. Not sure how the car bellhousings changed through the years, but the trucks changed from group to group. | | |
#68692 11/16/2006 5:34 AM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I know the rear motor mount for the 55 - 59 V8 cars are different than the same year of truck. I would think the I6 mounts are also different, but I can't locate any parts in a quick search.
I V8 and I6 truck bell housing bolts from the bottom of the crossmember with a single 1/2 bolt on each side, whereas the pass, car V8 has two smaller bolts each side that bolt into the crossmember in the horizontal possition. I am not sure about the car I6. | | |
#68693 11/16/2006 6:02 AM | Joined: Oct 2005 Posts: 90 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 90 | Don't forget that the '60,'61 &'62 trucks have the hydraulic clutch and the shifting fork is on the opposite side of the bellhousing from the '47-'59 trucks | | |
#68694 11/16/2006 3:58 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | there are two that i am aware of. the difference is the large transmission input shaft hole where the tranny bolts to has two sizes. (example) the sm420 uses the smaller sized hole, the larger hole works w/ sm465's and T5's. I believe the difference is about a 1/4'' dia.
all later years of bell housings (same engine bolt pattern) will fit on an L6 &/or V8
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#68695 11/17/2006 1:44 AM | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | Thank you everyone for all the info!!!This site is really something. I don't know how we ever got along with out it!I,m in the middle of building a really neat 53 1/2 ton,on a s10 frame(which you guys tlod me how to do)with a 350 in it and if I knew how to put pics on here ,I would show you some of it.The 6cyl stick is going into a 42 1/2 ton in the future. A friend has the bellhousing and flywheel but not sure what it came out of.The 6 is out of my 56 chevy car, it might bolt up to the stock bellhousing in the 42 now that I think of it . I'll check that out tomorrow. Thanks again!! | | |
#68696 11/18/2006 11:20 PM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | One thing to note on the pre 1947 truck bellhousings is that the clutch and master brake cylinder mount to the bellhousing. A later 47-54 bellhousing is a bolt up change, but it does not have the mounting holes for the pedal assembly. Jim Carter sells bellhousings (1947-1954) that have been modified for the pedal assembly in a pre 1947 truck. A more modern transmission... like the T-5, or muncie, or saginaw will bolt directly to the 47-54, or 55-59, or etc. The later transmissions will not bolt up to a pre 1947 bellhousing. | | |
#68697 11/19/2006 12:56 AM | Joined: Nov 2002 Posts: 59 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Nov 2002 Posts: 59 | 1947 truck bellhousings are the same as the earlier models. The reason for that is that the transmissions didn't change until 1948. All of the 47s including the late 47 Advance design models shared transmissions with the 1941-46 models. | | |
