0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Does anyone know if a '63 exhaust manifold will fit a '65 engine. I have a 1965 230 I need to replace the exhaust manifold and before I drive an hour to look at the '63 manifold I'd like to know if it'll work.
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | If it's a 230, i don't see any reason why not. The guy might have some other stuff you might need. It'll only be a wasted trip if you let it be one! | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | K10 is correct with an exception. If the 63 manifold is a 3 bolt 292 manifold, the down pipe is on a different angle. The good news is that the 3 bolt manifold is a bigger diameter than the 230/250.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
