7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible), 105 guests, and 5 robots.
Topics128,065
Posts1,055,863
Members48,428
#685750 10/13/2010 4:45 PM
Does anyone know if a '63 exhaust manifold will fit a '65 engine. I have a 1965 230 I need to replace the exhaust manifold and before I drive an hour to look at the '63 manifold I'd like to know if it'll work.
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
k10 Offline
If it's a 230, i don't see any reason why not. The guy might have some other stuff you might need. It'll only be a wasted trip if you let it be one!
K10 is correct with an exception. If the 63 manifold is a 3 bolt 292 manifold, the down pipe is on a different angle. The good news is that the 3 bolt manifold is a bigger diameter than the 230/250.
Larry
I don't own a vehicle that isn't old enough to drink.
