4 members (Cosmo, dt235sd, Gray_Ghost, Gdads51), 84 guests, and 2 robots.
Topics128,060
Posts1,055,840
Members48,427
#685806 10/13/2010 7:47 PM
Smokey 56
Smokey 56
Hi, I'm trying to make a game plan for our 57 3600. I would like to start removing the rear drivers fender, step and box side - will this be possible without dismanteling the whole box? If that is possible at that point also I would like to fix my cab corner since I will have more room. We don't have much space so we have to do a little at a time then turn the truck around and put it back in the garage to work on the pass side. Any help or suggestions would be great!
Dan
Dan and Melina from MN. 1956 Chevy/GMC custom 1 Ton dually step side short box.
I took my 58 apart last year, took off the hood all the fenders, lifted the bed off, removed the motor and tranny.This gives lots of room front and back to work. You also have lots of projects to keep you busy.When you start putting more back on than you take off you are making progress.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
Yes, you can but the tail gate will have to come off too. I think you will find it easier to dismantle the entire bed to get the most access to the cab corners. Keep your doors on when replacing those corners so you know everything is lined up.
Smokey 56
Smokey 56
Thanks hankrags for the info and reply!
Smokey 56
Smokey 56
Hi Jomichael! Thanks for the info - thats great news since I have very little room to work or store things, I can only remove so much at a time, then I will fix it and put it back on.
just remember, when you start to put it back together, get the doors finished and fit everything else to the doors.
Based on my experience, I tried to do in such tight spot couldnot get that far because once you start peeling the truck the sheet metals take up lot of space and you have consider good days outside and bad days outside. I ended up renting a tow car garage and it is still not a whole lot of space with tools and all the parts.
I wish you luck but my adivse is to look for some type of garage space for cheap and do it there.
Ganesh
