| | | Forums66 Topics128,038 Posts1,055,583 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | I have a '48 216 with a 3 spd column shift, and also have a spare 216 and 4 spd floor shift. Does anyone know if I can drop the 3 and install the 4 easily? Other than removing the column shift stuff, any other change I should expect? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 4-speed should swap in OK. The major "change" would be the 4-speed weighing twice as much. So, the 4-speed is not so easily lifted as is the 3-speed - I needed to use a jack for the 4-speed. I made this swap last Spring in my 1954 1/2 ton with enclosed driveshaft.
| | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | This trans was drained of the fluid. What is the preferred oil to use in a SM 420? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
