2 members (TexasA&M48Truck, Otto Skorzeny), 58 guests, and 3 robots.
Topics128,022
Posts1,055,381
Members48,422
#685532 10/13/2010 1:17 AM
I have a '48 216 with a 3 spd column shift, and also have a spare 216 and 4 spd floor shift. Does anyone know if I can drop the 3 and install the 4 easily? Other than removing the column shift stuff, any other change I should expect?
bowtiefan #685556 10/13/2010 2:06 AM
The 4-speed should swap in OK. The major "change" would be the 4-speed weighing twice as much. So, the 4-speed is not so easily lifted as is the 3-speed - I needed to use a jack for the 4-speed. I made this swap last Spring in my 1954 1/2 ton with enclosed driveshaft.
tclederman #687161 10/18/2010 12:08 PM
This trans was drained of the fluid. What is the preferred oil to use in a SM 420?
bowtiefan #687171 10/18/2010 1:39 PM
