| | | Forums66 Topics128,083 Posts1,056,331 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 27 New Guy | | New Guy Joined: Sep 2010 Posts: 27 | Anyone have any feedback on them? I have a 57, and got the kit.But am having fitment issues. 350engine/tranny. Tranny hits frame crossmember,can't lower rear of trans enough to fit the new crossmember.Also,the engine must drop about an inch to line uo with new engine mount,which would compound the tranny problem even more.Hope this makes sense. Called CPP,which is where the kit came from, but they weren't any help. Any other decent fitting conversion kits available? | | | | | Joined: Oct 2010 Posts: 21 New Guy | | New Guy Joined: Oct 2010 Posts: 21 | I have a 59 short bed with a 383 small block and a Art Carr 400 tranny with a Gear Vendor overdrive. The front engine mount will fit in the frame channel straight across and the tranny has about a 4" drop from the frame channel.
1940 Chevy 1 1/2 ton, 1959 Chevy 1/2 ton, 1966 Chevy C20.
I can explain it to you but I can't help you understand it.
| | | | | Joined: Sep 2010 Posts: 27 New Guy | | New Guy Joined: Sep 2010 Posts: 27 | Did your tranny hit the frame crossmember? | | | | | Joined: Oct 2010 Posts: 21 New Guy | | New Guy Joined: Oct 2010 Posts: 21 | I am so sorry that I did not tell you, but you must remove the crossmember. Note the you will need to weld the tubular pipe to the tie downs and then bolt to the frame.
| | | | | Joined: Sep 2010 Posts: 27 New Guy | | New Guy Joined: Sep 2010 Posts: 27 | I am so sorry that I did not tell you, but you must remove the crossmember. Note the you will need to weld the tubular pipe to the tie downs and then bolt to the frame. Excellent. Thanks for checking in! | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | Removal of that cross member may require cutting it into. On my 58 I could not get it out in one piece. Make sure everything is where you want it before you weld. drill a hole through the tubular pipe and tie downs and put in a bolt to keep everything aligned as you bolt it to the frame. When it all fits do the welding. | | |
