| | | Forums66 Topics128,192 Posts1,057,351 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 1 New Guy | | New Guy Joined: Sep 2010 Posts: 1 | All This is all new to me, working on an old truck and trying to communicate the type of help I need. I have a 1951 Chevy ½ ton Pick-up, that’s in “OK” condition (it runs). The problem that I am experiencing is this, after driving the truck for 5 or 10 minutes the brakes lock-up. I am not sure if it is all four wheels that lock-up, or just the front or just the rear. On one occasion I notice some smoke coming from the right rear wheel. Note: After the truck is parked for 5 or 10 minutes the brakes release. About a year and a half ago, I had a mechanic install new brakes and brake cylinders (Possibly rebuilt cylinders). Also, the Master Cylinder appears to in good condition. I have not driven the truck very much over the past year and a half due to charging and electrical problems. Note: I am not mechanically inclined. Any help or suggestion will be greatly appreciated. C-Lee
| | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Emergency brake maybe? Bad linkage or something bent linkage?
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | If it's the rear, pull the wheels and check for any oil leaking. If you have a bad rear seal it could be getting into the drum and swelling the brake linings.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If someone rebuilt the master cylinder ain the past they my have reversed the plunger stop when they reassembled it. That will allow pressure to be applied to the system but it blocks off the compensation port and it will take a good while for the pressure to bleed back and releas the brakes. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Check for free play in the master cyl. pushrod. It must have a small amount or it will hold the master cyl piston from coming all the way back like Denny says. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | One more thing--check your hard brake lines to see if any are bent in or pressed together. Will let high-pressure brake flued through, but will keep the shoes tight for several minutes while it leaks down back through the clogged part.
Not as likely to be the problem, but I have heard of that and if my memory serves me correctly, I had it happen once way back in the day.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Oct 2009 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 136 | I had the same problem with my rear brakes, I cleaned and readjusted brakes after putting new return springs on the shoes. | | | | | Joined: Sep 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 51 | I would check the brake line hoses. They really should be replaced every so often. In time they swell inside, so you can't see it. You press the brake pedal and there is enough presure to force past the restricted hoses but it can't easily flow back. It's also piece of mind to replace the old rubber hoses.
Love the classics! 1954 3100 1965 Mustang vert
| | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | my 51 did the same it ended up being the rear seal leaking on the pads | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | could just be adjusted a little too tight. Scott | | |
