1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#685113 10/11/2010 7:07 PM
Just wondering what tire size you guys are running? I purchased new wheels 15x7 6-5.5. I was running P205/60R-15's on the front and P255/60R-15's on the rear to give it a bit of hot rod look, even though its original mostly. These tires now need to be replaced and was looking at more of equal tire size on all 4 this time around. Any suggestions
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/
Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time.
TXChevy50 #685295 10/12/2010 11:44 AM
From what you said it sounds like you have two different wheel widths, {15x7 6-5.5 }, which doesn't add up to running the same size on all four.
I would run as wide as I could on the front and the same on the rear, if you want all four the same.
I don't know how you use your truck, but things to consider when you go wider up front are how it will affect steering and handling.
The wider you go up front the more you have to deal with what the road gives you. Without PS it's harder to steer with wide tires up front, especially when parking.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
glasman #685310 10/12/2010 12:50 PM
{15x7 6-5.5 } - Is the size of all 4 Rims that were purchased. Tire size was different however. Short in the front and tall and wide in the rear. My truck will be used for just cruising around the local area 50 mile radius.
Was wanting to look at keep the wheels all the same so I could rotate the tires, etc.
TXChevy50 #685341 10/12/2010 2:18 PM
If you convert mm to in. to see what will best fit that wheel which is 7 in wide you will see that-
205 = 8"
215 = 8 1/2"
225 = 8 7/8"
235 = 9 1/4"
255 = 10" too wide for that wheel,needs an 8 in wheel.
I'd be looking at a 225 or 235 as my choice, but that depends on what will work up front.
You already know a 205 works, the question is how much larger can you go up front.
A 215 is not much wider than 205, but you could could consider it also.
One other thing... different makes of tires will be slightly different in size even though the listed size is the same.
It's like...all tires are not created equal, just close !
Dan
glasman #685343 10/12/2010 2:29 PM
As far as width I am fine with a 205, just wanting more height without running into issues(fender, steering, etc). Right now the 205 60R -15 looks small in the wheel well. One to fill it out better.
TXChevy50 #685371 10/12/2010 4:02 PM
If you're gonna stay at stock height put some 235 75R 15's on it. They're about 28.8 inches tall. To find the best look on your truck find some free worn out tires at a tire shop in different sizes and mount them on your rims. Put them on to see how they look. The front will be where you need to check clearances the most. Get a 215 75's and a 225 and a 235 to compare. It might cost 20 bucks but will save you money down the road by getting tires you like the look of and fit nicely.
gotgasd #685377 10/12/2010 4:25 PM
P205-75-R15's are 26.5" diameter, P215-75-R15's are 27" diameter as a comparison. Just measured mine from a couple of trailers I have.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
gotgasd #685379 10/12/2010 4:33 PM
heres a pic of a 50 0n 235 75R 15
My wheels are 15 x 6
I had to run 1/4 spacers Due to the Dishonest people at Stockton Wheel. The tires where included in the package.
Tires are not truck tires.
I have front disc set up and modern tie-rods on the steering.
It would be nice if the forum had a sticky where members could post a pic of thier bolt and include just tire and wheel info, tire wheel size, spacer, mods, stock, lower, hot rod.
Good luck
DADS50 #686108 10/14/2010 3:31 PM
Found the perfect picture for the tire stance I want. Not sure what size they are or where I even got the picture originally.
http://dcntool.tripod.com/48_FC102_5.jpg
Anyone know what size these are?
TXChevy50 #686165 10/14/2010 6:50 PM
Try your lynk again, all I get is the logo.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #686181 10/14/2010 7:34 PM
That site acts funny about remote linking pics... It started working again just a minute again. Goes down if to may people are looking at it.
Any how, I posted a new entry with the pic on my blog link below as well. Should be no issues see it there..
l
l
V
