| | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | Just got a new speedometer cable for my 49truck on a 64 4spd 4x4 chassis,and drive line, it didn't have one before and i cant find were to hook it up to, i heard it hooks up to the transmission but i don't see anywhere to hook it up to. There is a spot on the Transfer but the cable doesn't seem to want to go into it? could the old one just be broke off in there or am i looking in the wrong spot? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | If the truck has been used/abused with no cable in place then it could be plugged with anything from the old cable to mud and dirt. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | | | | | | Joined: Mar 2010 Posts: 76 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 76 | It makes a 90degree turn immediately when it leaves the transfer case. | | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | alright so the hole on top of the transfer case is it. Thanks | | | | | Joined: Oct 2010 Posts: 15 New Guy | | New Guy Joined: Oct 2010 Posts: 15 | It is located where the output shaft comes out. As stated earlier it makes a sharp 90 degree turn when it comes out. My truck has the 90 degree turn and a grease fitting on it. If it was like mine, you could barely make it out due to the greasy grimy build up on it. | | |
