4 members (ndkid275, Hush, frogfarmer, BillCollins), 101 guests, and 0 robots.
Topics128,087
Posts1,055,974
Members48,430
1 Offline
Just got a new speedometer cable for my 49truck on a 64 4spd 4x4 chassis,and drive line, it didn't have one before and i cant find were to hook it up to, i heard it hooks up to the transmission but i don't see anywhere to hook it up to. There is a spot on the Transfer but the cable doesn't seem to want to go into it? could the old one just be broke off in there or am i looking in the wrong spot?
If the truck has been used/abused with no cable in place then it could be plugged with anything from the old cable to mud and dirt.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
transfer case
ron
It makes a 90degree turn immediately when it leaves the transfer case.
1965 Chevy Shortbed Fleetside
4 Wheel Drive K1445
More pix in Photobucket
1 Offline
alright so the hole on top of the transfer case is it. Thanks
It is located where the output shaft comes out. As stated earlier it makes a sharp 90 degree turn when it comes out. My truck has the 90 degree turn and a grease fitting on it. If it was like mine, you could barely make it out due to the greasy grimy build up on it.
