6 members (ranchojuan, MikeStone1953, Biermann, Philipj, Peggy M, Wayne67vert), 71 guests, and 2 robots.
Topics128,153
Posts1,056,849
Members48,456
Chevy 51 1/2 ton
On my 250 motor I am using a holley carb with an offenhauser manifold. I was wondering how to connect the wiper motor on it? There are two threaded ports on the side closes to the firewall on the mannifold. http://www.jegs.com/i/Offenhauser/750/5416/10002/-1?parentProductId=764102 Can I use one of these with 90 degree fitting to feed the wip\per motor. Also I think, if I use Delco fuel pump 6603 I should have the required vacuumed fuel pump.....Am I correct on this?
Thx
I think the manifold port you want to use for vacuum wipers is the smaller one near the center of the manifold.
Drew
You could use either port on the intake for a manifold vacuum source. you can get adaptors that plug in to hook your vacuum hose to. Or there should be a vacuum port on your carb. What kind of Holley are you using? I run an Offy and Holley 350 2 barrel on mine.
I am using the the same, a holley 350 2 barrel. I thought the vacuum port on the carb needed to be connected to the distributor advance...Am I wrong to assume this?
Just another question I don't have a vacuum fuel pump but was thinking of buying the 6603 Delco to hook up as original. Can I get away with simply hooking up the wiper motor to the manifold or would I benefit from having the wiper motor hooked up from the fuel pump and the manifold to the fuel pump too?
Gotgasd, do you have a picture of your set up? I haven't done my accelarator linkage or watering route for my heat plate and can really benefit with some visual. I am mentally struggling how am I going to run lines from the heater to the heating valve, then to the water pump and the to the manifold....That's alot of hoses
Thank you
Thx DrewP, I think you are right the smaller hole would be easier to find an adapter for.
Do you have a pic of your motor too. I'll get a good pic of mine today and link it for you.
This is mine
[IMG]http://i567.photobucket.com/albums/ss113/jimenezdesigngroup/th_250engine2.jpg[/IMG]
[IMG]http://i567.photobucket.com/albums/ss113/jimenezdesigngroup/th_250engine3.jpg[/IMG]
Here's mine. As you can see I ran my carb with the float bowl towards the valve cover. Easier for throttle hookup and my manual choke too. I ran the one hose off my heat plate around the back of the motor. My offy valve cover is closer to the thermostat housing so no room for a hose to go through there.
Nice to see you using Langdon's headers.
http://s992.photobucket.com/home/gotgasd
After looking at a Delco 6603 fuel pump I realized that thing is big but it shows to be right application for a 250 chevy motor. Anyone got a picture of one installed? I am afraid it my interfer with the distributor.
Thx
this is my set up on a 235. the lighter colored pipe goes to the dual action fuel pump and the other goes down to the power brakes under the floor.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Really nice set up
